[PROJ] Help in setting proj parameters for an old map
aborruso aborruso at gmail.com
Mon Feb 3 00:34:59 PST 2020
Pierre Abbat wrote
> I think it's more likely that the mapmaker forgot to put the scale factor.
> Check the other maps in the south Italy zone.
After clicking in a lot I have found this (a 0.99906 scale factor):
https://i.imgur.com/rchBzN9.png
Then I will use in this way in proj:
+proj=lcc +lat_0=39.50 +lon_0=14 +lat_1=39.50 +x_0=700000 +y_0=600000
+ellps=bessel +units=m +no_defs
Am I wrong?
Thank you again Pierre
Sent from: http://osgeo-org.1560.x6.nabble.com/PROJ-4-f3840930.html
More information about the PROJ mailing list
