[PROJ] "Fallback" support for transformations
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Tue Feb 4 05:37:02 PST 2020
Even,
My understanding is that the approach of the Dutch transformation could have been encoded in the EPSG registry if we didn't use a fixed height in the 7 parameter transformation. This is a bit ironic since we only use a fixed height to get the same results as with the second variant, which we created only because this is more widely supported by software.
Regards, Jochem
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: dinsdag 4 februari 2020 13:52
To: proj at lists.osgeo.org
Subject: Re: [PROJ] "Fallback" support for transformations
(Regarding what Jochem describes for the Dutch transformation, the variant with the fading out is indeed a smart approach, but too smart to be encoded in the EPSG database (at least currently), and thus being automatically proposed by PROJ in a proj_create_crs_to_crs_from_pj() / proj_create_operations() use case. Could probably be done with a custom entry in the PROJ db, but that's another topic. So for now, you need to specify "at hand" such PROJ pipeline. )
Even
http://www.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ
