[PROJ] cs2cs and +towgs84
Kristian Evers kreve at sdfe.dk
Wed Feb 5 05:14:07 PST 2020
Stefano,
cs2cs uses the ”best guestimate” operation between source and destination CRS.
If you want something else you need to specify that yourself. projinfo can help you
find the correct transformation:
$ projinfo -k operation -o PROJ EPSG:1660
PROJ string:
+proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +proj=push +v_3 +step +proj=cart +ellps=intl +step +proj=helmert +x=-104.1 +y=-49.1 +z=-9.9 +rx=0.971 +ry=-2.917 +rz=0.714 +s=-11.68 +convention=position_vector +step +inv +proj=cart +ellps=WGS84 +step +proj=pop +v_3 +step +proj=unitconvert +xy_in=rad +xy_out=deg +step +proj=axisswap +order=2,1
Which you can then use with cct:
$ echo 41.7447031 15.0618939 | cct -z0 -t0 -d8 +proj=pipeline +step +proj=axisswap +order=2,1 +step +proj=unitconvert +xy_in=deg +xy_out=rad +step +proj=push +v_3 +step +proj=cart +ellps=intl +step +proj=helmert +x=-104.1 +y=-49.1 +z=-9.9 +rx=0.971 +ry=-2.917 +rz=0.714 +s=-11.68 +convention=position_vector +step +inv +proj=cart +ellps=WGS84 +step +proj=pop +v_3 +step +proj=unitconvert +xy_in=rad +xy_out=deg +step +proj=axisswap +order=2,1
  41.74535412    15.06180323    0.00000000        0.0000
That should do the trick :-)
Please don’t use the +towgs84 parameter – it is deprecated and only supported for legacy reasons.
/Kristian
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Stefano Iacovella
Sent: 5. februar 2020 13:57
To: proj at lists.osgeo.org
Subject: [PROJ] cs2cs and +towgs84
Hello,
I already read the cs2cs usage page at [1] but I am still a little bit confused about the +towgs84 option so I am looking for your help.
I am trying to convert from EPSG:4265 CRS to EPSG:4326 CRS
First of all I used the following syntax
$> cs2cs -d 8 epsg:4265 epsg:4326
this way the coordinate are transformed but I have no control on which operation is really used, e.g. I don't know which are the towgs84's parameters
Really I want to use the EPSG:1660 operation, so I tried to add the +towgs84 option but I got an error:
$> cs2cs -d 8 epsg:4265 epsg:4326 +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
proj_create: crs not found
Rel. 6.3.0, January 1st, 2020
<cs2cs>:
cannot instantiate source coordinate system
program abnormally terminated
Which is the correct syntax to be used?
Thank you in advance
Stefano
[1] https://proj.org/apps/cs2cs.html
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200205/52d420e7/attachment-0001.html>
More information about the PROJ mailing list
