[PROJ] Releasing PROJ 6.3.1 ?
Even Rouault even.rouault at spatialys.com
Wed Feb 5 13:15:27 PST 2020
I believe we should release a 6.3.1 soon from the 6.3 branch.
When investigating the issue(s) raised in the following MapServer message
https://lists.osgeo.org/pipermail/mapserver-users/2020-February/081574.html,
I tried MapServer master (future 7.6) with PROJ 6.3.0 (using proj.h) and I get
crashes (or completely erroneous results) in a number of MapServer regression
tests. Those crashes are fixed by the following commit
https://github.com/OSGeo/PROJ/commit/79eed0da28abdc41c996dc55ee231f1fcffe4fd2
that was pushed post 6.3.0.
This commit also fixes issues with spatial R packages.
This is a bug dating back to 6.0.0 AFAIR but for some reason later 6.x
versions exhibit it much more easily than before. It is connected with the use
of the legacy +init=epsg:XXXX syntax that is still heavily used by MapServer
tests (and likely user mapfiles). It could probably be workaround on MapServer
side, but I'd feel more relieved if we issued a 6.3.1
"Celui qui dit, c'est celui qui fait" as one says here, which probably means
I'm volunteering to do that release.
Even
http://www.spatialys.com
More information about the PROJ mailing list
