[PROJ] Releasing PROJ 6.3.1 ?
Kristian Evers
kreve at sdfe.dk
Thu Feb 6 00:09:41 PST 2020
> "Celui qui dit, c'est celui qui fait" as one says here, which probably means
I'm volunteering to do that release.
In that case, no problem for me :-) When do you want to release it? Alongside 7.0.0?
It would probably be a good idea to go through pull request from the last couple of
weeks and backport whatever applies to 6.3.x. I stopped doing that after the decision
to keep proj_api.h, so there may be a few fixes missing in the 6.3 branch.
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: 5. februar 2020 22:15
To: proj at lists.osgeo.org
Subject: [PROJ] Releasing PROJ 6.3.1 ?
I believe we should release a 6.3.1 soon from the 6.3 branch.
When investigating the issue(s) raised in the following MapServer message
https://lists.osgeo.org/pipermail/mapserver-users/2020-February/081574.html,
I tried MapServer master (future 7.6) with PROJ 6.3.0 (using proj.h) and I get
crashes (or completely erroneous results) in a number of MapServer regression
tests. Those crashes are fixed by the following commit
https://github.com/OSGeo/PROJ/commit/79eed0da28abdc41c996dc55ee231f1fcffe4fd2
that was pushed post 6.3.0.
This commit also fixes issues with spatial R packages.
This is a bug dating back to 6.0.0 AFAIR but for some reason later 6.x
versions exhibit it much more easily than before. It is connected with the use
of the legacy +init=epsg:XXXX syntax that is still heavily used by MapServer
tests (and likely user mapfiles). It could probably be workaround on MapServer
side, but I'd feel more relieved if we issued a 6.3.1
Even
http://www.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ
