[PROJ] "Fallback" support for transformations
Even Rouault even.rouault at spatialys.com
Thu Feb 6 06:48:27 PST 2020
> Another constraint
> for gsb files is that the resolution of the sparse parent grid should be a
> multiple of the resolution of the dense subgrid and that a subgrid should
> cover the area of an integer number of parent grid cells.
For what is worth, the Geodetic TIFF grids (GTG) format resulting from RFC4
doesn't have those NTv2 specific constraints: a subgrid must just fall inside
the extent of its parent.
Even
http://www.spatialys.com
More information about the PROJ mailing list
