[PROJ] Transformation for local grid
Pierre Chaponniere
pierrechapo at gmail.com
Mon Feb 10 01:11:03 PST 2020
Dear all,
I am struggling to elaborate a pipeline with proj v6.3 that would transform
lat long coordinates to a local grid system.
>From what I see, I have all the required parameters, so I did a 3 step
pipeline :
1/ transform from lat long wgs84 to projected using tmerc.
2/ run horizontal transformation which is a rotation around an origin - I
was thinking of using the the Molobadekas transform for this purpose
3/ vertical shift for which I have an origin as well, east and north slope
entries in ppm - i still need to figure how I'll pass this one...
So my proj line so far looks like this :
proj +proj=pipeline +step +proj=tmerc +lat_0=-1.90 +lon_0=115.90
+y_0=538.374 +x_0=5200.27 +ellps=GRS80 +step +proj=molobadekas
+convention=coordinate_frame +x=-9.85881089465147 +y=-0.172038726321603
+s=17.60710142 +rz=1485.3205006576768028 +px=5225.30897756133
+py=-830.070127940344
But I keep on having errors as 'malformed pipeline' or 'non-angular input
coordinates'...
Even trying to pass the Molobadekas transform on its own, I struggle...
Do you see anything that I am doing totally wrong here ?
Would be really appreciated to have your insight on this !
Thanks heaps,
Best regards,
Pierre C
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200210/b6f7c11e/attachment.html>
More information about the PROJ
