[PROJ] RFC4: last chance to comment before motion
Even Rouault
even.rouault at spatialys.com
Fri Jan 3 04:24:50 PST 2020
Hi Nyall,
> My understanding of the current API leads me to believe that this
> wouldn't be possible in the current RFC4 API. The missing bits would
> be:
> 1. Public api to query if the preferred operation between two crses
> requires a grid download for a certain area
> 2. (Thread safe) API to manually download a grid for a certain area
> What's your thoughts on this?
I appreciate your suggestions but I can see some difficulties:
- "requires a grid download for a certain area". Imagine that the case is
to reproject the 4 corners of Continental US. You just need (part of) the
grids at those points, not for the whole continent. More generally, this
depends on the 'density' of points on a given area with respect to the
resolution of grid(s).
- there is also the fact that the local cache is of limited size, so if for
the whole set of points to coordinates you'd need more than the cache
maximum size, eviction will occur. For that point, that could be potentially
avoided by making the cache size such that it never happens. I arbitrarily
decided for a default of 100 MB. The total size of GeoTIFF grids is close
to 500 MB currently. So if we set the default to a bit more than the total
size of grids, eviction would never occur. That said, this point is probably
only theoretical. The 2 largest files currently are egm08_25.tif (77 MB) and
BWTA2017.tif (70 MB), so even if you reprojected entire Baden-Wurttemberg
and referenced EGM08 height that would still below 100 MB.
So perhaps an easier & robust solution for your use case could be:
- for the transformation of interest, use the PROJ_GRID_AVAILABILITY_IGNORED
flag to have the operations returned in the ideal case. Then for each point to
transform, you check the first candidate operation whose area of use
intersects with the point. That's the one that would be selected in an ideal
world. If it references a grid that proj_coordoperation_get_grid_used()
indicate as not available, take note of it, and use the next operation that
doesn't need a grid or for which grids are available, to perform the
approximate coordinate transformation.
- at the end of this stage, collect the set of missing grids and download them
(entirely), and restart the transformation.
Which can be done with existing (non-RFC4) API.
Even
http://www.spatialys.com
More information about the PROJ
