[PROJ] test failure with 6.3.0 geodtest
Greg Troxel
gdt at lexort.com
Sun Jan 5 11:33:41 PST 2020
(I have been paged out for a while and realize I am testing things now
that I should have tested earlier.)
I recently updated the pkgsrc-wip entry for proj from 6.0.0 to 6.2.1.
All tests passed on NetBSD 8/amd64 (with no additional datumgrid files).
I then updated to 6.3.0 and the new datumgrids, which went like one
would expect.
Testing 6.3.0 (with no additonal grid files), I get failures in
geodtest:
PROJ 6.3.0: src/test-suite.log
# TOTAL: 1
# PASS: 0
# SKIP: 0
# XFAIL: 0
# FAIL: 1
# XPASS: 0
# ERROR: 0
.. contents:: :depth: 2
FAIL: geodtest
checkEquals fails: 1.001875e+07 != 3.002268e+07 +/- 1
checkEquals fails: 1.001875e+07 != 2.002072e+07 +/- 1
Planimeter0 fail: 2
checkEquals fails: 7.612398e-07 != 1000000 +/- 0.01
Planimeter29 fail: 1
FAIL geodtest (exit status: 2)
This seems to be two planimeter test cases only, and as I read the test
code, the rest of the planimeter cases are ok, as are all the rest of
the many test.
The system gets a clean pass from the floating-point test paranoia.
I assume this test passes on Linux/amd64. I am curious what other
platforms it has been run on, and results.
More information about the PROJ
