[PROJ] proj manual, versioning, download location
Even Rouault
even.rouault at spatialys.com
Wed Jan 15 15:58:52 PST 2020
Mike,
> https://proj-tmp.readthedocs.io/en/latest/
Looks great! (I was actually thinking today of using Travis or some other CI
doing checkouts of several branches, building the docs and copy them at
appropriate subdirectories)
Just a few observations:
The html target of docs/Makefile has a final step doing
@cp -r ../schemas $(BUILDDIR)/html/schemas
so as to have
https://proj.org/schemas/v0.1/projjson.schema.json
https://proj.org/schemas/v0.2/projjson.schema.json
I don't see files at:
https://proj-tmp.readthedocs.io/en/latest/schemas/v0.1/projjson.schema.json
or
https://proj-tmp.readthedocs.io/schemas/v0.1/projjson.schema.json
And similarly for the nasty hack just above in the Makefile removing the
namespace occurences you can see in
https://proj-tmp.readthedocs.io/en/latest/development/reference/cpp/
cpp_general.html
but not in
https://proj.org/development/reference/cpp/cpp_general.html
Are those post-Sphinx customization/hack steps doable ?
Even
http://www.spatialys.com
More information about the PROJ
