[PROJ] OSGeo incubation status
Martin Desruisseaux
martin.desruisseaux at geomatys.com
Fri Jan 24 05:35:58 PST 2020
Le 24/01/2020 à 13:46, Sebastiaan Couwenberg a écrit :
> Standards are notorious as well, not have the right to make
> modifications makes them non-free as well. We have this issue with OGC
> Document License works for example.
Right OGC document license is another topic to think about. A short
discussion can be viewed on
https://github.com/spdx/license-list-XML/issues/845 (OGC directory
participated briefly). Actually that license does not forbid
modifications, but it has a condition saying "if you modify it, then you
must change the namespace". It is a little bit similar to an Apache
license condition meaning "if you modify that software, then you can not
call it "Apache" anymore - use any other name at your choice". Except
that OGC document license goes one step further by requiring
programmatic namespace change, not only product name change. If the
files are XML, this means changing the XML namespace. If the files are
Java interfaces, this means changing the Java module/package names. If
the files were C++ headers, I guess it would mean changing the names
that we specify in "using" statements. The OGC document license said
that if the developer do such name change, then those files fall
automatically under OGC software license, which is BSD-like.
OGC welcome feedback about OGC license issues, provided that we keep the
goal of protecting standard integrity. I plan to start a discussion with
Apache legal team on this topic later this year, to explore how the
naming condition of OGC document license is acceptable (or not) to them,
and bring those feedback to OGC. If OSGeo has feedback to provide too
that would be good.
Regards,
Martin
More information about the PROJ
