[PROJ] Motion: adopt RFC 5
Kristian Evers kreve at sdfe.dk
Wed Jan 29 04:18:42 PST 2020
Even,
That is awesome. What is the procedure from now with regards to
releasing PROJ-data packages? The RFC says that we will be producing
a proj-datumgrid-geotiff-1.0 package (I guess we will call that proj-data-1.0?)
but how is that archive produced? Similar to the old grid packages, e.g.
mkdir build
cd build
cmake ..
make dist
Would be nice to have a HOWTORELEASE file to capture this knowledge.
Does the release procedure also require as CDN sync or is that done when
new files are registered?
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: 29. januar 2020 13:05
To: proj at lists.osgeo.org
Subject: Re: [PROJ] Motion: adopt RFC 5
RFC 5 implementation has now been merged into PROJ master, and in the
https://github.com/OSGeo/PROJ-data repository (was known transiently as proj-
datumgrid-geotiff), which is now the new home for grids & similar datasets.
https://github.com/OSGeo/PROJ-data/tree/master/grid_tools contains the tools &
documentation to create Geodetic TIFF grids (GTG)
And https://github.com/OSGeo/PROJ-data/blob/master/CONTRIBUTING.md contains
the workflow to follow for adding new data.
For now, https://cdn.proj.org/ contains both the initial grid names (like
egm96_15.tif), and the new ones following RFC 5 naming scheme
(us_nga_egm96_15.tif)
I'll remove next week the old files, so for the initial adopters of RFC 4,
please update to latest master now, so proj.db points to the new names.
Even
http://www.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
