[PROJ] PROJ 7.1.0 and PROJ-data 1.1.0
Even Rouault
even.rouault at spatialys.com
Wed Jul 1 05:55:00 PDT 2020
On behalf of the PROJ development team I am happy to announce the release
of PROJ 7.1.0 and PROJ-data 1.1.0. They offer both backward compatible feature
improvements and bug fixes over PROJ 7.0.x and PROJ-data 1.0.0
See release notes below for details. Download the source distributions here:
https://download.osgeo.org/proj/proj-7.1.0.tar.gz
(md5: https://download.osgeo.org/proj/proj-7.1.0.tar.gz.md5)
https://download.osgeo.org/proj/proj-7.1.0.zip
(md5: https://download.osgeo.org/proj/proj-7.1.0.zip.md5)
https://download.osgeo.org//proj/proj-data-1.1.tar.gz
https://download.osgeo.org//proj/proj-data-1.1.zip
7.1.0 Release Notes
Updates
+ New projections:
o Add square conformal projections from libproject:
- Adams Hemisphere in a Square
- Adams World in a Square I
- Adams World in a Square II
- Guyou
- Pierce Quincuncial
(#2148)
o Adams Square II: map ESRI WKT to PROJ string, and implement iterative
inverse method (#2157)
o Added IGH Oceanic View projection (#2226)
o Add wink2 inverse by generic inversion of forward method (#2243)
+ Database:
o Update to EPSG 9.8.12, ESRI 10.8.1 and import scope and remarks for
conversion (#2238) (#2267)
o Map the Behrman projection to cae when converting ESRI CRSes (#1986)
o Support conversion of Flat_Polar_Quartic projection method (#1987)
o Register 4 new Austrian height grids (see https://github.com/OSGeo/PROJ-data/pull/13)
and handle 'Vertical Offset by Grid Interpolation (BEV AT)' method (#1989)
o Add ESRI projection method mappings for Mercator_Variant_A, Mercator_Variant_B
and Transverse_Cylindrical_Equal_Area and various grid mappings (#2020) (#2195)
o Map ESRI Transverse_Mercator_Complex to Transverse Mercator (#2040)
o Register grids for New Caledonia (see https://github.com/OSGeo/PROJ-data/pull/16)
(#2051) (#2239)
o Register NZGD2000 -> ITRF96 transformation for NZGD2000 database (#2248)
o Register geoid file for UK added
(see https://github.com/OSGeo//PROJ-data/pull/25() (#2250)
o Register Slovakian geoid transformations with needed code changes (#2259)
o Register Spanish SPED2ETV2 grid for ED50->ETRS89 (#2261)
+ API:
o Add API function proj_get_units_from_database() (#2065)
o Add API function proj_get_suggested_operation() (#2068)
o Add API functions proj_degree_input() and proj_degree_output() (#2144)
o Moved proj_context_get_url_endpoint & proj_context_get_user_writable_directory
from proj_experimental.h to proj.h (#2162)
o createFromUserInput(): allow compound CRS with the 2 parts given by names,
e.g. 'WGS 84 + EGM96 height' (#2126)
o createOperations(): when converting CompoundCRS<-->Geographic3DCrs, do not
use discard change of ellipsoidal height if a Helmert transformation is
involved (#2227)
o proj_list_units() deprecated, superceeded by proj_get_units_from_database()
o proj_list_angular_units() deprecated, superceeded by proj_get_units_from_database()
+ Optimizations:
o tmerc/utm: add a +algo=auto/evenden_snyder/poder_engsager parameter (#2030)
o Extended tmerc (Poder/Engsager): speed optimizations (#2036)
o Approximate tmerc (Snyder): speed optimizations (#2039)
o pj_phi2(): speed-up computation (and thus inverse ellipsoidal Mercator and LCC) (#2052)
o Inverse cart: speed-up computation by 33% (#2145)
o Extended tmerc: speed-up forward path by ~5% (#2147)
+ Various:
o Follow PDAL's CMake RPATH strategy (#2009)
o WKT import/export: add support for WKT1_ESRI VERTCS synta (#2024)
o projinfo: add a --hide-ballpark option (#2127)
o gie: implement a strict mode with <gie-strict> </gie-strict> (#2168)
o Allow importing WKT1 COMPD_CS with a VERT_DATUM[Ellipsoid,2002] (#2229)
o Add runtime checking that sqlite3 is >= 3.11 (#2235)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200701/a1177874/attachment-0001.html>
More information about the PROJ
