[PROJ] specifying the search paths
Even Rouault
even.rouault at spatialys.com
Thu Jul 2 02:18:45 PDT 2020
On jeudi 2 juillet 2020 10:46:30 CEST Roger Bivand wrote:
> On Wed, 1 Jul 2020, Even Rouault wrote:
> > On mercredi 1 juillet 2020 17:33:05 CEST Roger Bivand wrote:
> >> Even,
> >>> Roger,
> >>>> I have a question about the use of
> >>>> proj_context_set_search_paths(PJ_DEFAULT_CTX, ...). On initiating PRØJ,
> >>>> I
> >>>> see from proj_info().searchpath that (now 7.1.0) I have three paths,
> >>>> the
> >>>> last two identical /usr/local/share/proj, and the first
> >>>> $HOME/.local/share/proj - which contains a cache.db.
> >>>> For testing on other platforms than my own, I need to change the first
> >>>> path to a temporary directory with write access, so that I do not write
> >>>> in
> >>>> the user space of the test platform. So I use
> >>>> proj_context_set_search_paths(PJ_DEFAULT_CTX, ...), providing the
> >>>> correct
> >>>> length of the vector of paths, and the paths themselves. The
> >>>> user-writeable path is first, as at startup. It, however, does not
> >>>> contain
> >>>> a cache.db file, even of zero length. After finding a coordinate
> >>>> operation
> >>>> (using a grid cached in $HOME/.local/share/proj), the temporary
> >>>> directory
> >>>> remains empty, $HOME/.local/share/proj is used despite not being on the
> >>>> active path list, and the operation completes successfully.
> >>>> This is, however, not what I need - I need the download to occur to the
> >>>> temporary directory, so that I can demonstrate that cache.db gets
> >>>> populated.
> >>>> May libproj be caching paths so that even if the path to the
> >>>> use-writeable
> >>>> directory has been set, it still uses the one determined on load, even
> >>>> if
> >>>> it had been renamed and is not on the this of search paths? I find the
> >>>> default use-writeable directory being re-created even when it is not on
> >>>> the declared list of search paths. I'm only using PJ_DEFAULT_CTX - is
> >>>> that
> >>>> the problem?
> >>> The location of the user writable directory for cache.db is not
> >>> controlled
> >>> through proj_context_set_search_paths(). You can get the location with
> >>> proj_context_get_user_writable_directory()
> >> Thanks for a rapid and full reply. My context is that in order to include
> >> runnable code examples in R packages, they need to meet a requirement not
> >> to cause data to be written outside the R temporary directory for the
> >> running instance irrespective of platform. So I need to control the
> >> address of the user-writeable directory completely in order to show users
> >> what is going on, and to permit the package to meet test requirements. I
> >> can try pj_context_set_user_writable_directory() understanding that it is
> >> not part of the public API, and will report back.
> > I'd say R shouldn't worry about what PROJ does under the hood. This is
> > just caching. An internal detail that shouldn't have observable effect
> > from pepole using the PROJ API. The purpose of this per-account directory
> > was that the cache could be shared by many PROJ using software: GDAL,
> > QGIS, etc.
> > If you consider using pj_context_set_user_writable_directory() for more
> > than testing, I'd suggest you to propose a pull request to move it to the
> > public API as proj_context_set_user_writable_directory().
> Trying to be non-invasive, I'm trying to use the available environment
> variables. When rgdal is loaded/attached to the running R environment, I
> used to copy out proj_info().searchpath; now, I'm setting
> PROJ_SKIP_READ_USER_WRITABLE_DIRECTORY and can (apparently) skip the user
> writable directory. From src/filemanager.cpp, line 1197 in master, at the
> top of proj_context_get_user_writable_directory(), I see the environment
> variable PROJ_USER_WRITABLE_DIRECTORY. So I try to use it:
> > library(rgdal)
> Loading required package: sp
> rgdal: version: 1.5-13, (SVN revision 1024)
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 3.1.1, released 2020/06/22
> Path to GDAL shared files: /usr/local/share/gdal
> GDAL binary built with GEOS: TRUE
> Loaded PROJ runtime: Rel. 7.1.0, August 1st, 2020, [PJ_VERSION: 710]
> Path to PROJ shared files: /usr/local/share/proj:/usr/local/share/proj
> PROJ CDN enabled:FALSE
> Linking to sp version:1.4-2
> To mute warnings of possible GDAL/OSR exportToProj4() degradation,
> use options("rgdal_show_exportToProj4_warnings"="none") before loading
> rgdal.
> > get_proj_search_paths()
> [1] "/usr/local/share/proj" "/usr/local/share/proj"
> > td <- tempfile()
> > dir.create(td)
> > Sys.getenv("PROJ_USER_WRITABLE_DIRECTORY")
> [1] ""
> > Sys.setenv("PROJ_USER_WRITABLE_DIRECTORY"=td)
> [1] "/tmp/RtmpogCuDh/fileac60e50159ef4"
> > .Call("get_proj_user_writable_dir", PACKAGE="rgdal")
> [1] "/home/rsb/.local/share/proj"
> But it seems that my get_proj_user_writable_dir(), calling:
> proj_context_get_user_writable_directory(PJ_DEFAULT_CTX, FALSE)
> reaches line 1194 in the function and finds that
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200702/2620e7bc/attachment-0001.html>
More information about the PROJ
