[PROJ] proj-data is 500MB
Javier Jimenez Shaw
j1 at jimenezshaw.com
Fri Jul 24 01:31:14 PDT 2020
Just one comment: if you have several programs that use proj-data, and each
one installs 500 MB, sounds like a waste of space, right?
Does it make sense to install proj-data only once?
Regards
Javier
El vie., 24 jul. 2020 10:16, Sebastiaan Couwenberg <sebastic at xs4all.nl>
escribió:
> On 7/24/20 10:00 AM, Jürgen E. Fischer wrote:
> > On Fri, 24. Jul 2020 at 09:41:02 +0200, Sebastiaan Couwenberg wrote:
> >> You could split up the grids per region and only depend on a subset
> >> (excluding au_*, ca_*, de_* & us_* removes most of the very large grids)
> >> and suggest the rest for the users to manually install when they need
> it.
> > I don't want to exclude de completely - esp. because there are grids
> that were
> > previously shipped among it. The ridiculously large Baden-Württemberg
> grid
> > wasn't and must be excluded.
> Then perhaps split the grids by size similar to the
> gmt-gshhg-{low,high,full} packages.
> The gmt package in Debian only Recommends gmt-gshhg-low because of size
> constraints for OSGeoLive, despite the authors wanting the full package
> installed by default.
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200724/b3e32e9d/attachment.html>
More information about the PROJ
