[PROJ] proj-data is 500MB
Duncan Agnew
dagnew at ucsd.edu
Fri Jul 24 06:28:10 PDT 2020
I take Kristian's point, but FWIW would suggest that the geoid grids might
be a separate download option, for those who want to be able to do heights.
Those who don't plan to use this new functionality wouldn't need them, I
assume.
Duncan Agnew
On Fri, Jul 24, 2020 at 12:41 AM Sebastiaan Couwenberg <sebastic at xs4all.nl>
wrote:
> On 7/24/20 9:31 AM, Jürgen E. Fischer wrote:
> > On Fri, 24. Jul 2020 at 10:22:56 +0300, Idan Miara wrote:
> >> Jürgen suggests proj 7.1 can't be included in OSGeo4W/QGIS installer
> >> because proj-data is 500MB, which is too big.
> >> Is it intentionally so big?
> > It includes all the grids. And it's not a dependency. The grids can
> also be
> > downloaded dynamically, so using proj-data is probably only intended to
> be used
> > if that's not possible for some reason. You can also interactively
> download
> > the grids that you need via cdn.proj.org. QGIS does currently not
> support the
> > dynamic download and we don't know which grid the users will need
> upfront - so
> > either including none or all seems to be the only option. Given that
> QGIS
> > previously shipped several grids by default, shipping none probably
> isn't an
> > option either - as that would break some installations.
> You could split up the grids per region and only depend on a subset
> (excluding au_*, ca_*, de_* & us_* removes most of the very large grids)
> and suggest the rest for the users to manually install when they need it.
> 100.00% 523111200 ( 523.11 MB) .
> 15.41% 80585622 ( 80.59 MB) ./us_nga_egm08_25.tif
> 13.96% 73022201 ( 73.02 MB) ./de_lgl_bw_BWTA2017.tif
> 5.21% 27272664 ( 27.27 MB)
> ./au_icsm_GDA94_GDA2020_conformal_and_distortion.tif
> 3.26% 17033175 ( 17.03 MB) ./us_noaa_g2012bu0.tif
> 3.21% 16767965 ( 16.77 MB) ./us_noaa_geoid09_conus.tif
> 3.20% 16742155 ( 16.74 MB) ./us_noaa_g2018u0.tif
> 3.14% 16451024 ( 16.45 MB) ./us_noaa_geoid03_conus.tif
> 2.44% 12781759 ( 12.78 MB) ./au_ga_AUSGeoid09_V1.01.tif
> 2.19% 11478497 ( 11.48 MB) ./us_noaa_geoid06_ak.tif
> 2.17% 11342483 ( 11.34 MB) ./us_noaa_g2012ba0.tif
> 2.16% 11279068 ( 11.28 MB) ./us_noaa_geoid09_ak.tif
> 2.11% 11031336 ( 11.03 MB) ./ca_nrc_CGG2013an83.tif
> 2.11% 11030895 ( 11.03 MB) ./ca_nrc_CGG2013n83.tif
> 2.08% 10906276 ( 10.91 MB) ./ca_nrc_CGG2013ai08.tif
> 2.08% 10906091 ( 10.91 MB) ./ca_nrc_CGG2013i08.tif
> 1.53% 8002286 ( 8.00 MB) ./ca_nrc_ON27CSv1.tif
> 1.49% 7784410 ( 7.78 MB) ./ca_nrc_ntv2_0.tif
> 1.40% 7300425 ( 7.30 MB) ./ca_nrc_ON76CSv1.tif
> 1.36% 7114024 ( 7.11 MB) ./dk_sdfe_gvr2016.tif
> 1.18% 6180460 ( 6.18 MB) ./ca_nrc_MAY76V20.tif
> 1.13% 5934098 ( 5.93 MB) ./au_icsm_National_84_02_07_01.tif
> 1.12% 5839686 ( 5.84 MB) ./au_ga_AUSGeoid2020_20180201.tif
> 1.00% 5232082 ( 5.23 MB) ./nz_linz_nzgeoid2016.tif
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200724/d15b11f0/attachment.html>
More information about the PROJ
