[PROJ] How to write LAS points in N-E CRS
Even Rouault even.rouault at spatialys.com
Mon Jun 29 08:14:34 PDT 2020
> The same question could apply to ShapeFiles.
Shapefile .prj uses ESRI WKT1, which is even older than GDAL WKT1
and has no way to convey axis definition. The tradition seems to
always write coordinates in easting, northing  / longitude,latitude
order even when the full EPSG definition mentions the reverse
order.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200629/4ac44118/attachment-0001.html>
More information about the PROJ mailing list
