[PROJ] Can't Find proj.db
Even Rouault
even.rouault at spatialys.com
Fri Mar 20 12:20:51 PDT 2020
Andrew,
> - I created the items in this docker container by moving files from another
> location to /usr/lib, /usr/share, etc.
That's the likely issue. Running under strace will show you which paths are
attempted.
> - I don't know if the path-relative finding is in this version, but I wrote
> a small program to verify that dladdr() resolves to the correct
> libproj.so.15 location.
Path-relative finding logic has been added in 7.0, so that explains what you
see.
Even
http://www.spatialys.com
More information about the PROJ
