[PROJ] Calling for 7.0.1 release
Devrim Gündüz
devrim at gunduz.org
Tue Mar 24 13:41:09 PDT 2020
On Tue, 2020-03-24 at 17:05 +0100, Sebastiaan Couwenberg wrote:
> Then I don't really see how a 7.0.1 release is going to help unless you
> don't retool the sources.
I won't patch configure.ac. Is that an enough reason?
> You can also patch proj.pc to have the expected patch to not require
> automake to generate it for you.
Did you see the patch that I sent you in this thread?
Anyway, this is what I get after applying that patch:
make[1]: Entering directory `/home/pgsql/git/pgrpms/rpm/redhat/master/proj70/EL-7/proj-7.0.0'
CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /var/lib/pgsql/git/pgrpms/rpm/redhat/master/proj70/EL-7/proj-7.0.0/missing aclocal-1.16 -I m4
/var/lib/pgsql/git/pgrpms/rpm/redhat/master/proj70/EL-7/proj-7.0.0/missing: line 81: aclocal-1.16: command not found
WARNING: 'aclocal-1.16' is missing on your system.
You should only need it if you modified 'acinclude.m4' or
'configure.ac' or m4 files included by 'configure.ac'.
The 'aclocal' program is part of the GNU Automake package:
<https://www.gnu.org/software/automake>
It also requires GNU Autoconf, GNU m4 and Perl in order to run:
<https://www.gnu.org/software/autoconf>
<https://www.gnu.org/software/m4/>
<https://www.perl.org/>
make[1]: *** [aclocal.m4] Error 127
make[1]: Leaving directory `/home/pgsql/git/pgrpms/rpm/redhat/master/proj70/EL-7/proj-7.0.0'
error: Bad exit status from /var/tmp/rpm-tmp.SWFIwE (%build)
> Seems easy enough to workaround on systems where the toolchain is too old.
You are missing a point from packaging point of view. A packager should not
need aclocal while building from tarball.
Regards,
Devrim Gündüz
Open Source Solution Architect, Red Hat Certified Engineer
Twitter: @DevrimGunduz , @DevrimGunduzTR
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200324/9585bf95/attachment.sig>
More information about the PROJ
