[PROJ] How does proj deal with ellipsoid with respect to reprojection
Martin Desruisseaux martin.desruisseaux at geomatys.com
Sat Mar 28 09:02:10 PDT 2020
Le 28/03/2020 à 16:30, Even Rouault a écrit :
> And given that the implementation of gnomonic is for a sphere only,
> the flattening of WGS84 is ignored. So you'll get the same result as
> if it was a sphere of radius 6378137 metres.
Just a little note in case it may be considered worth to apply: in
situations where spherical formulas are used with an ellipsoid, EPSG
approach is often to use the authalic radius (the radius of a sphere of
same surface than the ellipsoid) instead than the semi-major axis length.
https://en.wikipedia.org/wiki/Earth_radius#Authalic_radius
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200328/b1187786/attachment.html>
More information about the PROJ mailing list
