[PROJ] How does proj deal with ellipsoid with respect to reprojection
Charles Karney
charles at karney.com
Sat Mar 28 09:47:55 PDT 2020
Maybe one of these days I'll get around to implementing the ellipsoidal
version of the gnomonic projection in PROJ. I derived this in
Algorithms for Geodesics (2013) and it's been in GeographicLib since
2010. With this projection, geodesics on the ellipsoid and *nearly*
straight. It's a good way of converting several problems involving
geodesics into equivalent 2d problems.
By the way, the documentation labels the gnomonic projection as
"pseudocylindrical". This should be "azimuthal".
On 3/28/20 10:58 AM, DeTracey, Brendan wrote:
> Hi,
> I am using a gnomonic projection for point in polygon testing. The transformation is:
> projinfo -s EPSG:4326 -t ' +type=crs +ellps=WGS84 +datum=WGS84 +proj=gnom +lat_0=61.39107201212929 +lon_0=-58.56360634793518'
> Will transformed great circles still be straight lines? Or does the fact that my source and target ellipse/datum are the same mean the gnomonic projection has the WGS4 coordinates passed directly to it? My confusion comes from gnomonic only being defined for a sphere, not an ellipsoid.
> Any clarification would be appreciated.
> Thanks,
> Brendan
More information about the PROJ
