[PROJ] Implemtation of WKT in cs2cs
Fandré Josianne jfandre at student.ethz.ch
Thu May 14 04:10:25 PDT 2020
Hi
I'm trying to use a WKT string to transform between two CSs but I haven't found any examples on how to do this. I'm using the OSGeo4W Shell and all attempts so far didn't work. I'm using the following code:
cs2cs +init=epsg:4326 +to +proj_create_from_wkt(0,"GEODCRS[„WGS 84“,DATUM[„World Geodetic System 1984“,ELLIPSOID[“WGS 84”,6378137,298.257223563,LENGTHUNIT[“metre”,1.0]]]CS[ellipsoidal,2],AXIS[“latitude”,north,ORDER[1]],AXIS[“longitude”,east,ORDER[2]],ANGLEUNIT[“degree”,0.0174532952]]") . I tried using +proj_create() as well but I get each time the error:proj_create: unrecognized format / unknown name.
Thank you
Josianne
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200514/f70c736e/attachment.html>
More information about the PROJ mailing list
