[PROJ] Explaining geodesic distance discrepancies
Dima Kogan
proj at dima.secretsauce.net
Fri May 15 14:00:06 PDT 2020
Thank you very much. That's VERY useful info. How did you get that scale
factor? Is there a proj tool and/or function call?
I have just tried to run the "geod" cmd on another box with another proj
install, and it matches up over there. Which is probably enough for me
to go figure this out. We DO expect the "geod" cmdline and the
pyproj.Geod results to match 100%, right?
Thanks again.
More information about the PROJ
