[PROJ] About unit conversion
José Luis García Pallero jgpallero at gmail.com
Wed May 20 09:34:09 PDT 2020
El mié., 20 may. 2020 a las 11:00, Kristian Evers (<kreve at sdfe.dk>) escribió:
> I see that you don't specify the input units in your unitconvert steps. Try adding a
> +xy_in parameter to your unitconvert steps and see if that fixes the problem.
> When you only specify of of either +xy_in or +xy_out the operation becomes
> somewhat uni-directional which is why not all of your pipelines works in reverse.
> See https://proj.org/operations/conversions/unitconvert.html for more.
Thank you for your answer, Kristian, but I can't understand why my
program fails. Clearly, for FWD and input in radians and output in
meters all works without any unitconversion. Also for INV step with
meters as input and radians as output, i.e., using only "+proj=utm
+lon_0=3w +ellps=GRS80" as parameters string is enough. Also for any
combination in the FWD step all works.
For example using "+proj=pipeline +step +proj=unitconvert +xy_in=deg
+step +proj=utm +lon_0=3w +ellps=GRS80 +step +proj=unitconvert
+xy_out=km" accepts as input degrees and returns kilometers. But I
cant understand why in this case for the INV step the parameters
string "+proj=pipeline +step +proj=unitconvert +xy_in=km +step
+proj=utm +lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=deg"
is incorrect. I've tested several combinations and none of them works:
"+proj=utm +lon_0=3w +ellps=GRS80" -> wrong results
"+proj=pipeline +step +proj=unitconvert +xy_in=km +step +proj=utm
"+proj=pipeline +step +proj=unitconvert +xy_in=km +xy_out=m +step
+proj=utm +lon_0=3w +ellps=GRS80" -> wrong results (same numeric value
as before)
"+proj=pipeline +step +proj=unitconvert +xy_in=km +xy_out=deg +step
+proj=utm +lon_0=3w +ellps=GRS80" -> proj_create: Error -59
(inconsistent unit type between input and output): Pipeline: Bad step
definition: proj=unitconvert (inconsistent unit type between input and
output)
"+proj=pipeline +step +proj=utm +lon_0=3w +ellps=GRS80 +step
+proj=unitconvert +xy_in=km +xy_out=deg" -> proj_create: Error -59
output)
"+proj=pipeline +step +proj=unitconvert +xy_out=deg +step +proj=utm
+lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_in=km" -> wrong
results
+lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=deg" -> wrong
results
I can't understand the way as unitconvert works, neither reading
For only one conversion (km to radians or meters to degrees) the
problem is only again with the INV step
Thanks
> /Kristian
> > -----Original Message-----
> > From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of José Luis García
> > Pallero
> > Sent: 19. maj 2020 10:59
> > To: proj at lists.osgeo.org
> > Subject: Re: [PROJ] About unit conversion
> > I've written a small program in order to illustrate my last mail.
> > Attached (and pasted at the bottom of the message) I send the code.
> > The results are
> > Original data -> lon: -6.00000, lat: 43.00000 (degrees) -> lon:
> > -0.1047197551, lat: 0.7504915784 (radians)
> > rad to m  -> X= 255466.981, Y=4765182.933 (+proj=utm +lon_0=3w
> > +ellps=GRS80)
> > rad to km -> X=    255.467, Y=   4765.183 (+proj=pipeline +step
> > +proj=utm +lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=km)
> > deg to m  -> X= 255466.981, Y=4765182.933 (+proj=pipeline +step
> > +proj=unitconvert +xy_in=deg +step +proj=utm +lon_0=3w +ellps=GRS80)
> > deg to km -> X=    255.467, Y=   4765.183 (+proj=pipeline +step
> > m  to rad -> lon=-0.1047197551, lat= 0.7504915784 (+proj=utm +lon_0=3w
> > +ellps=GRS80)
> > km to rad -> lon=-0.0001306633, lat= 0.0000007501 (+proj=pipeline
> > +step +proj=unitconvert +xy_in=km +step +proj=utm +lon_0=3w
> > +ellps=GRS80)
> > m  to deg -> lon=-0.1300126568, lat= 0.0130928532 (+proj=pipeline
> > +xy_out=deg)
> > km to deg -> lon=-0.0001307025, lat= 0.0000000131 (+proj=pipeline
> > +ellps=GRS80 +step +proj=unitconvert +xy_out=deg)
> > As you can see, the only right INV conversion is the meters_to_radians
> > one. All other combinations produce all different results, but all
> > combinations for the FWD step are right. Im using PROJ 7.0.1 from the
> > Debian Sid repositories
> > #include<stdio.h>
> > #include<stdlib.h>
> > #include<math.h>
> > #include<proj.h>
> > #define CONST_PI (3.14159265358979323846264338328)
> > int main()
> >     double lond1=-6.0,latd1=43.0,lond2=lond1,latd2=latd1;
> >     double
> > lonr1=lond1*CONST_PI/180.0,latr1=latd1*CONST_PI/180.0,lonr2=lonr1,latr2
> > =latr1;
> >     char param_rad_to_m[]="+proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_rad_to_km[]="+proj=pipeline +step +proj=utm +lon_0=3w
> > +ellps=GRS80 +step +proj=unitconvert +xy_out=km";
> >     char param_deg_to_m[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=deg +step +proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_deg_to_km[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=deg +step +proj=utm +lon_0=3w +ellps=GRS80 +step
> >     char param_m_to_rad[]="+proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_km_to_rad[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=km +step +proj=utm +lon_0=3w +ellps=GRS80";
> >     char param_m_to_deg[]="+proj=pipeline +step +proj=utm +lon_0=3w
> > +ellps=GRS80 +step +proj=unitconvert +xy_out=deg";
> >     char param_km_to_deg[]="+proj=pipeline +step +proj=unitconvert
> > +xy_in=km +step +proj=utm +lon_0=3w +ellps=GRS80 +step
> >     PJ_CONTEXT *C=proj_context_create();
> >     PJ *proj=NULL;
> >     size_t ld=sizeof(double);
> >     //Display original data
> >     printf("Original data -> lon: %.5lf, lat: %.5lf (degrees) -> lon:
> > %.10lf, lat: %.10lf (radians)\n\n",
> >            lond1,latd1,lonr1,latr1);
> >     //FWD, radiands to meters
> >     proj = proj_create(C,param_rad_to_m);
> > proj_trans_generic(proj,PJ_FWD,&lonr1,ld,1,&latr1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("rad to m  -> X=%11.3lf, Y=%11.3lf
> > (%s)\n",lonr1,latr1,param_rad_to_m);
> >     proj_destroy(proj);
> >     //FWD, radiands to kilometers
> >     proj = proj_create(C,param_rad_to_km);
> > proj_trans_generic(proj,PJ_FWD,&lonr2,ld,1,&latr2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("rad to km -> X=%11.3lf, Y=%11.3lf
> > (%s)\n",lonr2,latr2,param_rad_to_km);
> >     proj_destroy(proj);
> >     //FWD, degrees to meters
> >     proj = proj_create(C,param_deg_to_m);
> > proj_trans_generic(proj,PJ_FWD,&lond1,ld,1,&latd1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("deg to m  -> X=%11.3lf, Y=%11.3lf
> > (%s)\n",lond1,latd1,param_deg_to_m);
> >     proj_destroy(proj);
> >     //FWD, degrees to kilometers
> >     proj = proj_create(C,param_deg_to_km);
> > proj_trans_generic(proj,PJ_FWD,&lond2,ld,1,&latd2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("deg to km -> X=%11.3lf, Y=%11.3lf
> > (%s)\n\n",lond2,latd2,param_deg_to_km);
> >     proj_destroy(proj);
> >     //INV, meters to radians
> >     proj = proj_create(C,param_m_to_rad);
> >     proj_trans_generic(proj,PJ_INV,&lonr1,ld,1,&latr1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("m  to rad -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lonr1,latr1,param_m_to_rad);
> >     proj_destroy(proj);
> >     //INV, kilometers to radians
> >     proj = proj_create(C,param_km_to_rad);
> >     proj_trans_generic(proj,PJ_INV,&lonr2,ld,1,&latr2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("km to rad -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lonr2,latr2,param_km_to_rad);
> >     proj_destroy(proj);
> >     //INV, meters to degrees
> >     proj = proj_create(C,param_m_to_deg);
> > proj_trans_generic(proj,PJ_INV,&lond1,ld,1,&latd1,ld,1,NULL,0,0,NULL,0,0);
> >     printf("m  to deg -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lond1,latd1,param_m_to_deg);
> >     proj_destroy(proj);
> >     //INV, kilometers to degrees
> >     proj = proj_create(C,param_km_to_deg);
> > proj_trans_generic(proj,PJ_INV,&lond2,ld,1,&latd2,ld,1,NULL,0,0,NULL,0,0);
> >     printf("km to deg -> lon=%13.10lf, lat=%13.10lf
> > (%s)\n",lond2,latd2,param_km_to_deg);
> >     proj_destroy(proj);
> >     proj_context_destroy(C);
> >     return 0;
> > El lun., 18 may. 2020 a las 23:03, José Luis García Pallero
> > (<jgpallero at gmail.com>) escribió:
> > > Hello:
> > > I'm trying to do dome projections (forward and inverse) using the
> > > function proj_trans_generic() and parameter string in PROJ format (+
> > > style) and I'm a bit confused about unit conversions. My reference for
> > > the syntax is https://proj.org/operations/conversions/unitconvert.html
> > > For the forward problem I write
> > > C = proj_context_create();
> > > projection = proj_create(C,param);
> > proj_trans_generic(projection,PJ_FWD,lon,sizeof(double),nElem,lat,sizeof(d
> > ouble),nElem,NULL,0,0,NULL,0,0);
> > > I've used the param string
> > > '+proj=pipeline +step +proj=unitconvert +xy_in=deg +step +proj=utm
> > > +lon_0=3w +ellps=GRS80 +step +proj=unitconvert +xy_out=km'
> > > which means that the input coordinates are in degrees and the output
> > > in kilometers. All works right. The results are the same if I pass the
> > > input coordinates in radians and I use the param string
> > > '+proj=pipeline +step +proj=utm +lon_0=3w +ellps=GRS80 +step
> > > The problem comes when I try to do the inverse step. The procedure is the
> > same:
> > proj_trans_generic(projection,PJ_INV,x,sizeof(double),nElem,y,sizeof(doubl
> > > In the input xoordinates are in meters and I use the param string
> > > '+proj=utm +lon_0=3w +ellps=GRS80'
> > > The resulting longtude and latitude are correct and the units are
> > > radians. But if I use the param string
> > > +proj=unitconvert +xy_out=deg'
> > > The output is totally wrong. I expect degrees, but the values have no
> > > sense. Also, if I use the input X and Y in kilometers ans the param
> > > string is
> > > '+proj=pipeline +step +proj=unitconvert +xy_in=km +step +proj=utm
> > > the result is wrong again.
> > > I suppose I'm doing something wrong with unit conversion, but I can not
> > find it
> > > Can someone help me?
> > > Thanks
> > > (o<
> > > V_/_
> > > Use Debian GNU/Linux and enjoy!
> > (o<
> > V_/_
(o<
V_/_
More information about the PROJ mailing list
