[PROJ] question regarding vertical shift
Mathieu Pellerin
nirvn.asia at gmail.com
Tue Nov 10 02:24:45 PST 2020
Javier, useful link, I think it did provide me with some higher level of
clarity :)
Thanks,
Mathieu
On Tue, Nov 10, 2020 at 5:10 PM Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Hi Mathieu
> I do not know if I understand your question correctly. In Switzerland the
> geoid is above the ellipsoid (about 50 meters). That is a positive geoid
> undulation. So the orthometric height (over the geoid) is smaller than the
> ellipsoidal height.
> This may clarify it:
> https://www.ngs.noaa.gov/GEOID/GSVS/
> Cheers
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Tue, 10 Nov 2020 at 10:39, Mathieu Pellerin <nirvn.asia at gmail.com>
> wrote:
>> Greetings,
>> I’m hoping the mailing list can enlighten me regarding handling of
>> vertical shift in PROJ.
>> Using this Switzerland vertical shift grid (
>> https://www.dropbox.com/s/6uzpg3gr47q1p1k/CHGeo04.gtx?dl=0), if I type
>> in the following command to adjust vertical height (100 meters here):
>> echo 7.9995 46.7949 100 | cct +proj=vgridshift +grids=CHGeo04.gtx
>> PROJ returns the following result:
>> 7.9995000000 46.7949000000 49.8406 inf
>> The adjusted height is 49.8 meters. This puzzles me as the grid’s value
>> at the provided longitude and latitude (i.e. 7.9995 46.7949) is 50.179. I
>> would have assumed that this meant a vertical adjustment of +50.179, not
>> -50.179 as observed by the PROJ returned values.
>> Is PROJ’s result the correct one based on the grid? Or should an inverse
>> transformation (i.e. cct -t) be used here? If so, what’s the rationale of
>> whether to pick forward or inverse transformation?
>> Regards,
>> Mathieu Pellerin
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201110/d6a6db49/attachment.html>
More information about the PROJ
