[PROJ] Transformation to rotated pole
Even Rouault even.rouault at spatialys.com
Sat Nov 21 06:32:26 PST 2020
Ken,
Not completely clear if you want to reproject from or into rotated pole, but
you'll fix trivially the below depending on your need.
shapefile .prj AFAIK cannot store a rotated pole CRS, so I'd just try to do it
in one step, with the following modified & corrected CRS ("+proj=latlon" was
wrong, it should be "+proj=ob_tran +o_proj=latlon")
ogr2ogr -s_srs "+proj=ob_tran +o_proj=latlon +lat_0=0 +lon_0=180 +o_lat_p=18.0
+o_lon_p=-200.0 +datum=WGS84 +type=crs"  -t_srs EPSG:4326 output.shp
source.shp
You may need a quite recent PROJ version for that to work correctly due to
ob_tran being complicated to handle when "computing" transformation pipelines.
Actually I just did a fix in PROJ master (https://github.com/OSGeo/PROJ/pull/
2441) for ob_tran if there was a +towgs84 term (you don't need one here, as
+a=6378137 +rf=298.257223563 +towgs84=0,0,0 really means +datum=WGS84)
Or you can also directly specify the transformation pipeline which should
hopefully work with any GDAL >= 3 and PROJ >= 6
ogr2ogr -ct "+proj=pipeline +step +proj=unitconvert +xy_in=deg +xy_out=rad
+step +inv +proj=ob_tran +o_proj=latlon +lat_0=0 +lon_0=180 +o_lat_p=18
+o_lon_p=-200 +ellps=WGS84 +step +proj=unitconvert +xy_in=rad +xy_out=deg"
output.shp source.shp
if you add -t_srs EPSG:4326, you'll also likely need to add " +step
+proj=axisswap +order=2,1" at the end of the above pipeline to deal with the
lat,lon axis order of EPSG:4326
(for the reverse direction remove the +inv)
Even
http://www.spatialys.com
More information about the PROJ mailing list
