[PROJ] Why is Web Marcator EPSG:3857 so popular for web maps (vs EPSG:4326)?
Pierre Abbat phma at bezitopo.org
Thu Nov 26 15:07:40 PST 2020
On Thursday, November 26, 2020 8:47:06 AM EST Idan Miara wrote:
> 3. 3857 is "almost" conformal - I think that the normal use case is not
> marine navigation so it doesn't seem so important.
Marine navigation is not the only use of conformal maps. Surveyors use
conformal coordinate systems (in the USA, they're called state plane
coordinates, and most of them are Lambert conic or transverse Mercator) to
note coordinates of lot corners and benchmarks. When I put a tie to a
benchmark on a map and note the grid bearing to the nearest second, I know
that the angle between that tie and a boundary line is the same on the ground
as on the map (though measuring the boundary line's bearing to the nearest
second is difficult; at 100 m that's 0.5 mm).
Pierre
La sal en el mar es más que en la sangre.
Le sel dans la mer est plus que dans le sang.
More information about the PROJ mailing list
