[PROJ] EPSG v10 update status
Even Rouault
even.rouault at spatialys.com
Fri Oct 9 04:53:25 PDT 2020
Roger,
> Is there a specific PR/fork of GDAL that matches rouault/PROJ:epsg10?
> Testing for the R packages I'm involved with uses both, so GDAL would need
> to use PROJ functions adapted for v10.
To test just rouault/PROJ:epsg10, you don't need any special GDAL patched version as
the objects returned by PROJ will still have the same structure as before (no datum
ensemble)
To test rouault/PROJ:epsg10_part2 with GDAL, you need
https://github.com/OSGeo/gdal/pull/3033 that contains fixes for dealing with datum
ensemble.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20201009/a1fa1c15/attachment.html>
More information about the PROJ
