[PROJ] Anyway to set a CRS object's name via c api?
Nyall Dawson nyall.dawson at gmail.com
Fri Oct 9 14:40:43 PDT 2020
On Fri, 9 Oct 2020 at 21:04, Even Rouault <even.rouault at spatialys.com> wrote:
> Hi Nyall,
> > Using the C api "proj_get_name" method I'm able to retrieve the
> > descriptive name of a CRS object.
> > This works well for CRS obtained from the Proj database, or for CRS
> > defined from WKT with a name embedded: ...PROJCRS["my CRS name",
> > BASEGEOGCRS[...
> > But if I have a CRS object created using a different method (say, from
> > a proj string), is there any way I can manually set a name for this
> > CRS so that subsequent calls to proj_as_wkt will include the manually
> > set CRS name?
> > While it would be possible to get the WKT returned from proj_as_wkt
> > and then try to insert the custom name, this would be a lot of fragile
> > string manipulation which I'd rather avoid!
> /** \brief Return a copy of the object with its name changed
> * Currently, only implemented on CRS objects.
> * The returned object must be unreferenced with proj_destroy() after
> * use.
> * It should be used by at most one thread at a time.
> * @param ctx PROJ context, or NULL for default context
> * @param obj Object of type CRS. Must not be NULL
> * @param name New name. Must not be NULL
> * @return Object that must be unreferenced with
> * proj_destroy(), or NULL in case of error.
> PJ PROJ_DLL *proj_alter_name(PJ_CONTEXT *ctx, const PJ *obj, const char *name);
> Available in proj_experimental.h since 6.0
Perfect, thanks!
Nyall
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
More information about the PROJ mailing list
