[PROJ] EPSG v10 update status
Nyall Dawson nyall.dawson at gmail.com
Sat Oct 10 19:03:09 PDT 2020
> And possibly also try #2371, but if your code inspects the details of objects, like accessing the datum of a CRS, be prepared for the dreaded datum ensemble concept to show up (for anything based on WGS84 and ETRS89), in which case you may need to use new functions added in the C API.
Hi Even,
I've been trying to get my head around how the introduction of datum
ensembles will impact downstream projects, and specifically how things
will/should change for users of these applications.
Am I correct in my understanding that a ensemble is (at this stage) a
"metadata only" concept, which indicates that the datum is only
suitable for approximate spatial referencing? Or does a datum being
flagged as an ensemble also influence the operations determined by
PROJ and their order of precedence?
How would you imagine a downstream project like QGIS should respond to
this concept? Should we add a user-visible flag on any CRS definitions
associated with a datum ensemble to say "Warning: ensemble datum, not
for use in accurate spatial referencing"? What other user-facing
changes do you think should be introduced?
Nyall
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
