[PROJ] Using latest realization of a datum ensemble ?
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Sun Oct 18 08:25:50 PDT 2020
I agree with you, and especially with the idea of the need to educate PROJ and GIS users in avoiding datum ensembles. (I think some additional education is needed for the fact that WGS84 is NOT the official global geodetic reference frame but this is ITRS.) However, to make people stop using datum ensembles, some changes in EPSG are needed too.
Greg Troxel wrote:
> I think your idea of having entries in the database to lead to the transforms to most-recent-realization is a very promising appraoch, and probably the right approach.
I'm not sure if this is the best solution. However, I think this might be only realistic solution, as it reduces the amount of change needed in EPSG to something doable.
Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
More information about the PROJ mailing list
