[PROJ] PROJ 7.1.1 & PROJ-data 1.2
Kristian Evers
kristianevers at gmail.com
Tue Sep 1 07:16:51 PDT 2020
All,
It is my pleasure to announce the release of PROJ 7.1.1 and PROJ-data 1.2.
The former primarily includes a number of bug fixes as well as updates to
the CRS database. The data package includes a few new transformation grids
for use in Brazil and the Canary Islands.
Get the packages here:
http://download.osgeo.org/proj/proj-7.1.1.tar.gz
http://download.osgeo.org/proj/proj-7.1.1.zip
http://download.osgeo.org/proj/proj-data-1.2.tar.gz
http://download.osgeo.org/proj/proj-data-1.2.zip
See the release notes below.
/Kristian
7.1.1 Release Notes
Updates
o Added various Brazillian grids to the database #2277
o Added geoid file for Canary Islands to the database #2312
o Updated EPSG database to version 9.8.15 #2310
Bug fixes
o WKT parser: do not raise warning when parsing a WKT2:2015 TIMECRS
whose TIMEUNIT is at the CS level, and not inside #2281
o Parse '+proj=something_not_latlong +vunits=' without +geoidgrids as a
Projected3D CRS and not a compound CRS with a unknown datum #2289
o C API: Avoid crashing due to missing SANITIZE_CTX() in entry points
#2293
o CMake build: Check "target_clones" before use #2297
o PROJ string export of +proj=krovak +czech: make sure we export +czech…
#2301
o Helmert 2D: do not require a useless +convention= parameter #2305
o Fix a few spelling errors ("vgridshit" vs. "vgridshift") #2307
o Fix ability to identify EPSG:2154 as a candidate for 'RGF93_Lambert_93'
#2316
o WKT importer: tune for Oracle WKT and 'Lambert Conformal Conic' #2322
o Revert compiler generated Fused Multiply Addition optimized routines
#2328
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200901/18c1d302/attachment.html>
More information about the PROJ
