[PROJ] Any EPSG code for visualization order WGS84(s)?
Roger Bivand
Roger.Bivand at nhh.no
Sun Sep 6 04:00:42 PDT 2020
There are plenty of EPSG codes for authority-conformant axis orders of
WGS84 (not only 4326, but also 9053-9056, 9012, 9014, 9017, 9019, and
possibly others). In userland in R (and most likely GRASS, QGIS, SAGA,
PostGIS (?), pyproj, web mapping, etc.), visualization order is absolutely
the most commonly used and expected.
We are starting to see visualization order points reported and saved as
4326, with no indication that the declared CRS should have been
axis-swapped before saving. This leads to chaos when the file is read and
treated as real 4326 in another application.
It would be a real simplification if there was an EPSG code (or codes) for
WGS84 GEOGCRS with visualization axis order to match the way that most
applications have conceptualized objects up to now. For now we have ad-hoc
work-arounds, but no way for non-global data sets to check that points are
E/N or N/E.
Is there such an EPSG code (or codes); if not, who and how can apply to
the "authorities" to provide support for such a wierd thing? Of course,
having such an alternative set would permit easy coordinate operations of
the +proj=axisswap +order=2,1 kind, but not as ad-hoc additions to
existinng pipelines.
Many different ad-hoc fixes are less good than a single central and
authorised resolution, and EPSG codes for visualization order WGS84-family
GEOGCRS are clearly needed by most applications.
Any ideas?
Roger
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
More information about the PROJ
