[PROJ] "Local" projection method?
Noel Zinn (cc) ndzinn at comcast.net
Thu Sep 24 03:39:07 PDT 2020
Here’s more on the Ellipsoidal Orthographic FYI:
http://www.hydrometronics.com/downloads/Ellipsoidal%20Orthographic%20Projection.pdf
Esri refer to this as their Local Cartesian Projection.
No need for authalic latitude in the ellipsoidal case.
Noel Zinn, Principal, Hydrometronics LLC
+1-832-539-1472 (office), +1-281-221-0051 (cell)
noel.zinn at hydrometronics.com (email)
http://www.hydrometronics.com (website)
Sent: Thursday, September 24, 2020 4:01 AM
To: proj at lists.osgeo.org
Subject: Re: [PROJ] "Local" projection method?
On jeudi 24 septembre 2020 05:42:22 CEST Kristian Evers wrote:
> Nyall,
> > Based on this, would it be appropriate to directly map this projection
> > method across to the "Orthographic" method? Or am I missing something
> > important?…
> Yes, it would seem so. Be aware though, the current Orthographic projection
> implementation in PROJ is only valid in the spherical case. You would have
> to extend that to the ellipsoidal case for the mapping described by Esri.
> We’ve got an old issue [0] which contains some hints on how to go about
> that.
"Recent" EPSG guidance note 7.2
https://drive.tiny.cloud/1/4m326iu12oa8re9cjiadxonharclteqb4mumfxj71zsttwkx/62018e48-9da4-43e7-b598-1202cd96ec9f
(link got from epsg.org)
has the maths for the ellipsoidal formulation of the orthographic projection in paragraph 3.3.5, page 89
I cannot comment on the full equivalence of the "Local" projection, but hopefully in the Scale_Factor=1 + Azimuth=0 case, they would match.
One way to check that the theory local = ortho on the sphere is valid would be to use ArcGIS with a sphere as the ellipsoid and compare results with +proj=ortho
Other point:
Looking at
https://pro.arcgis.com/en/pro-app/help/mapping/properties/orthographic.htm ,
there's the Auxiliary Sphere Type parameter that can be used to change how orthographic is computed on an ellipsoid, but I'm not sure any of the listed method is equivalent to the ellipsoidal formulation from EPSG, as the ellipsoidal formulation from EPSG doesn't seem to use authalic latitude.
Even
http://www.spatialys.com
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200924/761b7a70/attachment-0001.html>
More information about the PROJ mailing list
