[PROJ] Pipeline from "Local" projection to EPSG:4326
Even Rouault
even.rouault at spatialys.com
Fri Sep 25 08:42:34 PDT 2020
On vendredi 25 septembre 2020 15:22:40 CEST Māris Nartišs wrote:
> Hello folks,
> I got a dataset with custom CRS in "Local" projection and have been
> trying unsuccessfully to set up a pipeline to transform coordinates
> into 4326.
See discussion thread
https://lists.osgeo.org/pipermail/proj/2020-September/thread.html#9818
in case you missed it
> To get correct results in ArcGIS, I have to select two transformations
> – EPSG:15844 followed by EPSG:15843
> I was trying various ways how to create pipeline for testing with
> cs2cs/cct in 6.3.1 but no luck. As pipelines are a new feature, there
> are not so many examples floating around unfortunately – didn't manage
> to get syntax right.
> Thus:
> 1) how should such pipeline look like? (looking at shapefile
> transformed with ArcGIS, a point from 22000 77000 should land at
> 69.2642191 41.3335608)
> Here's content of .prj file:
> PROJCS["Local_Tashkent",GEOGCS["GCS_Pulkovo_1942",DATUM["D_Pulkovo_1942",SPH
> EROID["Krasovsky_1940",6378245.0,298.3]],PRIMEM["Greenwich",0.0],UNIT["Degre
> e",0.0174532925199433]],PROJECTION["Local"],PARAMETER["False_Easting",24547.
> 608],PARAMETER["False_Northing",76540.608],PARAMETER["Scale_Factor",1.0],PAR
> AMETER["Azimuth",0.0],PARAMETER["Longitude_Of_Center",69.295403],PARAMETER["
> Latitude_Of_Center",41.329238],UNIT["Meter",1.0]]
Changing in your above WKT "Local" to "Orthographic",
projinfo -s
'PROJCS["Local_Tashkent",GEOGCS["GCS_Pulkovo_1942",DATUM["D_Pulkovo_1942",SPHER
OID["Krasovsky_1940",6378245.0,298.3]],PRIMEM["Greenwich",0.0],UNIT["Degree",
0.0174532925199433]],PROJECTION["Orthographic"],PARAMETER["False_Easting",
24547.608],PARAMETER["False_Northing",76540.608],PARAMETER["Scale_Factor",
1.0],PARAMETER["Azimuth",0.0],PARAMETER["Longitude_Of_Center",
69.295403],PARAMETER["Latitude_Of_Center",41.329238],UNIT["Meter",1.0]]' -t EPSG:4326
--spatial-test intersects
gives:
Candidate operations found: 12
Operation No. 1:
unknown id, Inverse of unnamed + axis order change (2D) + Pulkovo 1942 to WGS 84 (16), 4.5
m, Europe - FSU onshore
PROJ string:
+proj=pipeline +step +inv +proj=ortho +lat_0=41.329238 +lon_0=69.295403 +x_0=24547.608
+y_0=76540.608 +ellps=krass +step +proj=push +v_3 +step +proj=cart +ellps=krass +step
+proj=helmert +x=25 +y=-141 +z=-78.5 +rx=0 +ry=-0.35 +rz=-0.736 +s=0
+convention=coordinate_frame +step +inv +proj=cart +ellps=WGS84 +step +proj=pop +v_3
+step +proj=unitconvert +xy_in=rad +xy_out=deg +step +proj=axisswap +order=2,1
REMARK["Derived via PZ-90 at 30 stations throughout USSR (Former Soviet Union,
FSU) through concatenation of Pulkovo 1942 to PZ-90 (1) (tfm code 15844) and PZ-90 to WGS
84 (1) (tfm code 15843)."]]],
Which must be as close as you wish
echo "22000 77000 0" | cct -d 8 +proj=pipeline +step +inv +proj=ortho +lat_0=41.329238
+lon_0=69.295403 +x_0=24547.608 +y_0=76540.608 +ellps=krass +step +proj=push +v_3
+step +proj=cart +ellps=krass +step +proj=helmert +x=25 +y=-141 +z=-78.5 +rx=0 +ry=-0.35
+rz=-0.736 +s=0 +convention=coordinate_frame +step +inv +proj=cart +ellps=WGS84 +step
+proj=pop +v_3 +step +proj=unitconvert +xy_in=rad +xy_out=deg +step +proj=axisswap
+order=2,1
41.33355118 69.26417454 0.00000000 inf
This isn't exactly the coordinates you mention, probably due to the issue of PROJ ortho not
implementing the ellipsoidal formulation whereas ESRI Local does.
> 2) how to make it "default" pipeline for the source CRS for all proj
> utilizing tools (ogr2ogr, QGIS etc.)?
This is a tricky aspect. The current philosophy is that you either trust PROJ automated way to
select the right pipeline (PROJ's cs2cs, GDAL utilities with no explicit pipeline, etc.), or you
choose it yourself (with PROJ's cct utility, GDAL's ogr2ogr/gdalwarp -ct switch, QGIS UI datum
change preference dialog box)
You could manage to change PROJ's default by tweeking PROJ's db. Either by adding a new
record to it with a better accuracy than the ones present, or modifying the accuracy of an
existing transform to be better than the best one presented by PROJ
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200925/769734b9/attachment.html>
More information about the PROJ
