[PROJ] "Local" projection method?
Nyall Dawson
nyall.dawson at gmail.com
Fri Sep 25 17:35:39 PDT 2020
On Sat, 26 Sep 2020 at 07:02, Even Rouault <even.rouault at spatialys.com> wrote:
> On jeudi 24 septembre 2020 11:01:22 CEST Even Rouault wrote:
> > On jeudi 24 septembre 2020 05:42:22 CEST Kristian Evers wrote:
> > > Nyall,
> > > > Based on this, would it be appropriate to directly map this projection
> > > > method across to the "Orthographic" method? Or am I missing something
> > > > important?…
> > > Yes, it would seem so. Be aware though, the current Orthographic
> > > projection
> > > implementation in PROJ is only valid in the spherical case. You would have
> > > to extend that to the ellipsoidal case for the mapping described by Esri.
> > > We’ve got an old issue [0] which contains some hints on how to go about
> > > that.
> > "Recent" EPSG guidance note 7.2
> > https://drive.tiny.cloud/1/4m326iu12oa8re9cjiadxonharclteqb4mumfxj71zsttwkx/
> > 62018e48-9da4-43e7-b598-1202cd96ec9f
> > (link got from epsg.org)
> > has the maths for the ellipsoidal formulation of the orthographic projection
> > in paragraph 3.3.5, page 89
> I gave this a try at https://github.com/OSGeo/PROJ/pull/2361
> with mapping from ESRI WKT Local to +proj=ortho
Thanks Even -- that's much appreciated!!
Nyall
More information about the PROJ
