[PROJ] Transforming from epsg:4326 to epsg:31468 produces a 2 meter offset
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Thu Apr 15 08:43:36 PDT 2021
Greg wrote:
> make proj choose to transform to WGS84(G1762) when asked to transform to or from WGS84 and submit a patch :-)
That is a good idea that would make my life easier too. I think EPSG should do that instead of PROJ?
However, the real solution is to make people stop using EPSG:4326.
Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
More information about the PROJ mailing list
