[PROJ] Is there Doxygen documentation?
Even Rouault
even.rouault at spatialys.com
Wed Apr 21 03:41:09 PDT 2021
Javier,
GDAL publishes Doxygen because it used to do it before we switched to
Sphinx.
PROJ Doxygen doc isn't pushed on proj.org, but you can consult it locally
Run ./scripts/doxygen.sh
and open generated files in docs/build/doxygen_html/index.html
Even
Le 21/04/2021 à 12:21, Javier Jimenez Shaw a écrit :
> Hi
> In GDAL you can use two different C++ documentations:
> - Sphinx : https://gdal.org/api/index.html#id3
> <https://gdal.org/api/index.html#id3>
> - Doxygen : https://gdal.org/doxygen/index.html
> <https://gdal.org/doxygen/index.html>
> However in PROJ I could only find it in Sphinx format
> - https://proj.org/development/reference/cpp/index.html#
> <https://proj.org/development/reference/cpp/index.html#>
> Am I missing something? Is there doxygen style doc for PROJ somewhere?
> Thanks.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210421/7f1d0730/attachment.html>
More information about the PROJ
