[PROJ] PROJ 8.0.1RC1 and PROJ-data 1.6RC1
Kristian Evers
kristianevers at gmail.com
Wed Apr 28 03:49:23 PDT 2021
All,
I have prepared candidates for the upcoming PROJ 8.0.1 and PROJ-data 1.6 releases.
The packages are available from
http://download.osgeo.org/proj/proj-8.0.1RC1.tar.gz
http://download.osgeo.org/proj/proj-8.0.1RC1.zip and
http://download.osgeo.org/proj/proj-data-1.6RC1.tar.gz
http://download.osgeo.org/proj/proj-data-1.6RC1.zip
The PROJ release includes a number of bug fixes and updates to the transformation database
(see details below). The data package is extended with grids and tinshift files for Norwegian
transformations and the Swiss CHGeo2004 geoid model.
Please test the release candidates and report your findings back to the mailing list.
/Kristian
8.0.1 Release Notes
Updates
o Database: update to EPSG v10.018 (#2636)
o Add transformations for CHGeo2004, Swiss geoid model (#2604)
o Additions to the norwegian NKG2020 transformation (#2600)
Bug fixes
o pj_vlog(): fix buffer overflow in case of super lengthy error message (#2693)
o Revert "proj_create_crs_to_crs_from_pj(): do not use PROJ_SPATIAL_CRITERION_PARTIAL_INTERSECTION if area is specified" (#2679)
o UTM: error out when value of +zone= is not an integer (#2672)
o getCRSInfoList(): make result order deterministic (by increasing auth_name,
code) (#2661)
o createOperation(): make sure no to discard deprecated operations if the
replacement uses an unknow grid (#2623)
o Fix build on Solaris 11.4 (#2621)
o Add mapping of ESRI Equal_Area projection method to EPSG (#2612)
o Fix incorrect EPGS extent code for EPSG:7789>EPSG:4976 NKG transformation (#2599)
o fix wrong capitalization of CHENyx06_ETRS.gsb (#2597)
o createOperations(): improve handling of vertical transforms when
when compound CRSs are used (#2592)
o CRS::promoteTo3D(): propagate the extent from the 2D CRS (#2589)
o createFromCRSCodesWithIntermediates(): improve performance when there is
no match (#2583)
o Fix proj_clone() to work on 'meta' coordinate operation PJ* objects that
can be returned by proj_create_crs_to_crs() (#2582)
o add PROJ_COMPUTE_VERSION, PROJ_VERSION_NUMBER,
PROJ_AT_LEAST_VERSION macros (#2581)
o Make proj_lp_dist() and proj_geod() work on a PJ* CRS object (#2570)
o Fix gcc 11 -Wnonnull compilation warnings (#2559)
o Fix use of uninitialized memory in gie tests (#2558)
o createOperations(): fix incorrect height transformation between 3D promoted RGF93 and CH1903+ (#2555)
More information about the PROJ
