[PROJ] PROJ 8.0.1RC1 and PROJ-data 1.6RC1
Sebastiaan Couwenberg sebastic at xs4all.nl
Wed Apr 28 04:38:30 PDT 2021
On 4/28/21 1:30 PM, Kristian Evers wrote:
> Yes, that’s possible. Will the files be identical though? I know some systems
> use MD5 (or similar) hashes to verify that they’ve got the right file. I would
> assume that will break if I regenerate the file. Probably not the highest risk
> to do it on a release candidate but still…
The checksums will be different, tar is easily reproducible, although
pristine-tar does a reasonable job. The checksums can be updated along
with the tarballs.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
