[PROJ] BoundCRS with BBox
Olivier PENA
OPena at isagri.fr
Wed Aug 18 10:09:20 PDT 2021
Done : https://github.com/OSGeo/PROJ/issues/2813
Thanks
De : Even Rouault <even.rouault at spatialys.com>
Envoyé : mercredi 18 août 2021 13:59
À : Olivier PENA <OPena at isagri.fr>; proj at lists.osgeo.org <proj at lists.osgeo.org>
Objet : Re: [PROJ] BoundCRS with BBox
Olivier,
hum, good finding. This is actually an oversight of the implementation. The WKT2 grammar (http://docs.opengeospatial.org/is/18-010r7/18-010r7.html#149) does indeed allow usage/scope/extent/id/remark for a bound CRS but our C++ classes do not allow for that now. Could you file a ticket in https://github.com/OSGeo/PROJ/issues/new about that ?
Even
Le 18/08/2021 à 13:38, Olivier PENA a écrit :
Hi
I’m looking for a way to set area of use for a BoundCRS I define with WKT like this one :
BOUNDCRS[
SOURCECRS[
PROJCRS["Monte Mario / Italy zone 2",
BASEGEOGCRS["Monte Mario",
DATUM["Monte Mario",
ELLIPSOID["International 1924",6378388,297,
LENGTHUNIT["metre",1]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433]],
ID["EPSG",4265]],
CONVERSION["unnamed",
METHOD["Transverse Mercator",
ID["EPSG",9807]],
PARAMETER["Latitude of natural origin",0,
ANGLEUNIT["degree",0.0174532925199433],
ID["EPSG",8801]],
PARAMETER["Longitude of natural origin",15,
ID["EPSG",8802]],
PARAMETER["Scale factor at natural origin",0.9996,
SCALEUNIT["unity",1],
ID["EPSG",8805]],
PARAMETER["False easting",2520000,
LENGTHUNIT["metre",1],
ID["EPSG",8806]],
PARAMETER["False northing",0,
ID["EPSG",8807]]],
CS[Cartesian,2],
AXIS["x",east,
ORDER[1],
LENGTHUNIT["metre",1]],
AXIS["y",north,
ORDER[2],
ID["EPSG",3004]]],
TARGETCRS[
GEOGCRS["WGS 84",
DATUM["World Geodetic System 1984",
ELLIPSOID["WGS 84",6378137,298.257223563,
CS[ellipsoidal,2],
AXIS["latitude",north,
ORDER[1],
AXIS["longitude",east,
ORDER[2],
ID["EPSG",4326]]],
ABRIDGEDTRANSFORMATION["Transformation from Monte Mario to WGS84",
METHOD["Position Vector transformation (geog2D domain)",
ID["EPSG",9606]],
PARAMETER["X-axis translation",-50.2,
ID["EPSG",8605]],
PARAMETER["Y-axis translation",-50.4,
ID["EPSG",8606]],
PARAMETER["Z-axis translation",84.8,
ID["EPSG",8607]],
PARAMETER["X-axis rotation",-0.69,
ID["EPSG",8608]],
PARAMETER["Y-axis rotation",-2.012,
ID["EPSG",8609]],
PARAMETER["Z-axis rotation",0.459,
ID["EPSG",8610]],
PARAMETER["Scale difference",0.99997192,
ID["EPSG",8611]]],
USAGE[
SCOPE["unknown"],
AREA["Italy - Sicily onshore"],
BBOX[36.59,12.36,38.35,15.71]]
I would be happy if proj_get_area_of_use() on the crs return the Sicily BBox.
I ran a debug session and it seems that USAGE node is not taken account in buildBoundCRS() in io.cpp. Same behavior in the json parser.
Is this normal behavior ?
Thanks
PROJ mailing list
PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210818/49ddeda0/attachment.html>
More information about the PROJ
