[PROJ] Changes in area of use bounds for EPSG 3035 between major versions
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Aug 18 10:50:23 PDT 2021
It seems a change in EPSG.
This is the CRS: https://epsg.org/crs_3035/ETRS89-extended-LAEA-Europe.html
This is the Extent: https://epsg.org/extent_2881/Europe-LCC-LAEA.html
that was modified in January 2021:
https://epsg.org/closed-change-request/browse/id/2020.127
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Wed, 18 Aug 2021 at 19:34, Stephan Hügel <urschrei at gmail.com> wrote:
> We’ve recently updated the PROJ version in use by rust-proj from 7.2.1 to
> 8.1.0, which caused a test failure:
> One of our tests interrogates the area of use for EPSG:3035 using
> get_area_of_use. In 7.2.1, that was:
> west, -35.58
> south, 24.6
> east, 44.83
> north, 84.17
> But north has changed to 84.73 in v8.1.0
> I’m not claiming this is wrong, but it’s a large change so I thought I’d
> ask if anyone can shed some light on it…
> s
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210818/6ae724e5/attachment.html>
More information about the PROJ
