[PROJ] PROJ 8.1.1RC1
Kristian Evers
kristianevers at gmail.com
Wed Aug 25 20:54:48 PDT 2021
All,
I have prepared a release candidate for the upcoming version 8.1.1 of PROJ.
Archives are available here
http://download.osgeo.org/proj/proj-8.1.1RC1.tar.gz
http://download.osgeo.org/proj/proj-8.1.1RC1.zip
The PROJ release includes a number of bug fixes and updates to the
transformation database (see details below).
Please test the release candidates and report your findings back
to the mailing list.
/Kristian
8.1.1 Release Notes
Updates
o EPSG Database updated to version 10.028 (#2773)
Bug Fixes
o Include algorithm header file to avoid build errors on Alpine Linux (#2769)
o CMake: fix installation of executables on iOS (#2766)
o Associate extents to transformations of CRS's that include GEOIDMODEL (#2769)
o Logging: avoid some overhead when logging is not enabled (#2775)
o ortho: remove useless and invalid log trace (#2777)
o CMake: remove external nlohmann_json from INTERFACE_LINK_LIBRARIES target (#2781)
o reateOperations(): fix SourceTargetCRSExtentUse::NONE mode (#2783)
o GeoTIFF grid reading: perf improvements (#2788)
o Conversion::createUTM(): avoid integer overflow (#2796)
o Inverse laea ellipsoidal: return PROJ_ERR_COORD_TRANSFM_OUTSIDE_PROJECTION_DOMAIN
when appropriates (#2801)
o Make sure that proj_crs_promote_to_3D returns a derived CRS (#2806)
o createOperations(): fix missing deg<-->rad conversion when transforming with a
CRS that has a fallback-to-PROJ4-string behaviour and is a BoundCRS of a
GeographicCRS (#2808)
o WKT2 import/export: preserve PROJ.4 CRS extension string in REMARKS[] (#2812)
o BoundCRS: accept importing/exporting in WKT2 and PROJJSON the
scope/area/extent/id attributes (#2815)
o ConcatenatedOperation::fixStepsDirection(): fix bad chaining of steps when
inverse map projection is involved in non-final step (#2819)
More information about the PROJ
