[PROJ] Pseudo-mercator
Martin Desruisseaux martin.desruisseaux at geomatys.com
Wed Dec 1 15:15:20 PST 2021
Hello
Le 01/12/2021 à 23:54, Andrew Patterson a écrit :
> (…snip…) I altered the WKT on that map from Mercator_1SP ->
> Mercator_2SP and changed 'latitude_of_center' to 'standard_parallel_1'
> and now it works exactly as in the old GDAL & PROJ.
Note: in EPSG database version 7.6 and later:
  * "Mercator (1SP)" has been renamed "Mercator (variant A)"
  * "Mercator (2SP)" has been renamed "Mercator (variant B)"
  * There is also a "Mercator (variant C)"
Maybe the renaming was done for making room for variant C, I don't know.
As Even said:
  * Variant A has a "Scale factor at natural origin" parameter.
  * Variant B has a "Latitude of 1st standard parallel" parameter.
  * Variant C has a "Latitude of false origin" parameter in addition of
    standard parallel.
The "latitude of center" parameter name in the old WKT may be confusing.
While variant B seems to work, having "center" in the parameter name
gives the impression that the projection could be variant C. The
"Latitude/longitude of false origin" of "Mercator (variant C)" define
the location where projected coordinates are (0,0), which may look like
a projection center (by contrast, "Latitude of 1st standard parallel"
does not have this effect).
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211202/8b9bb45d/attachment.html>
More information about the PROJ mailing list
