[PROJ] CRS explorer
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Sat Dec 4 04:54:28 PST 2021
Hi Javier,
Thanks for the nice improvements. I like the name filtering! It could be useful to be able to use this for other columns too, like the area of use and code.
I was wondering: Since you give the option to sort on a column, why do you present the CRS types (Projected, Geographic, Geocentric etc.) in separate tables? If you add a column for the CRS type in the table, then you could present everything in a single table and an user can still sort on CRS type if needed. The advantage would be that the user can also sort on other columns for all CRS types at once.
What does the option Sticky map do?
What function does the checkbox in the column Area of use have?
Regards, Jochem
From: PROJ <proj-bounces at lists.osgeo.org> on behalf of Javier Jimenez Shaw <j1 at jimenezshaw.com>
Sent: Friday, 3 December 2021, 16:01
To: proj
Subject: Re: [PROJ] CRS explorer
Hi all
Sorry for the late update to PROJ 8.2.0. I have been implementing it with GitHub Actions. But now it is available.
https://jjimenezshaw.github.io/crs-explorer/
Some features were added, like filtering by name, column ordering, better performance...
I was thinking on adding links to static pages with the WKT1 of each CRS. Do you think it is useful?
Cheers,
Javier
PS: I found some new astronomical CRSs (IAU_2015) that are type "other" in proj.db. What is that?
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Thu, 14 Oct 2021 at 12:57, Thomas Knudsen <knudsen.thomas at gmail.com<mailto:knudsen.thomas at gmail.com>> wrote:
Javier,
Thanks for developing this - it seems to be extremely useful!
/Thomas
Den tor. 14. okt. 2021 kl. 12.03 skrev Javier Jimenez Shaw <j1 at jimenezshaw.com<mailto:j1 at jimenezshaw.com>>:
Hi
I have developed a simple webpage to search coordinate reference systems based on PROJ data. It includes a map where you can click a location, filtering the systems that has this location in their area of use.
There are a couple of ideas to add in the backlog. But I hope it is already useful.
Cheers,
Javier.
PROJ mailing list
PROJ at lists.osgeo.org<mailto:PROJ at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/proj
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20211204/98b1bdaf/attachment.html>
More information about the PROJ mailing list
