[PROJ] Tie breakers used when ordering candidate operations
Even Rouault
even.rouault at spatialys.com
Wed Feb 10 07:01:33 PST 2021
Hi Nyall,
Obviously the doc was lagging a bit behind the latest state of the code.
Update in https://github.com/OSGeo/PROJ/pull/2522
> 11. consider as more relevant an operation that involves less
> transformation steps
> Here I'd have thought 8450 (with a single noop step) would be picked
> over 9690, which has a pipeline of:
> +proj=pipeline
> +step +proj=axisswap +order=2,1
> +step +proj=unitconvert +xy_in=deg +xy_out=rad
> +step +proj=push +v_3
> +step +proj=cart +ellps=WGS84
> +step +proj=helmert +x=0.06155 +y=-0.01087 +z=-0.04019 +rx=-0.0394924
> +ry=-0.0327221 +rz=-0.0328979 +s=-0.009994
> +convention=coordinate_frame +step +inv +proj=cart +ellps=GRS80
> +step +proj=pop +v_3
> +step +proj=unitconvert +xy_in=rad +xy_out=deg
If you look at the WKT output, you'll see that both have a single
transformation step, which is what is considered by the sorting algorithm. But
a helmert transformation with no translation and no rotation can be simplified
in a single PROJ operation.
So here only the final criterion apply. Given that "WGS 84 to GDA2020 (3)" >
"Inverse of GDA2020 to WGS 84 (2)" in lexicographic order, it has higher
precedence. Completely arbitrary here obviously...
Even
http://www.spatialys.com
More information about the PROJ
