[PROJ] PROJ 7.2.1 & PROJ-data 1.4
Kristian Evers kreve at sdfe.dk
Fri Jan 1 08:19:06 PST 2021
On behalf of the PROJ development team I am happy to announce the
release of PROJ 7.2.1 and PROJ-data 1.4.
The PROJ release includes updates to the database and a number of bug fixes.
See the detailed release notes below.
The PROJ-data package adds two new grid files (au_ga_AGQG_20191107.tif and
eu_nkg_nkgrf2017vel.tif) that are referenced in the database updates.
Get the packages here:
http://download.osgeo.org/proj/proj-7.2.1.tar.gz
http://download.osgeo.org/proj/proj-7.2.1.zip
http://download.osgeo.org/proj/proj-data-1.4.tar.gz
http://download.osgeo.org/proj/proj-data-1.4.zip
/Kristian
7.2.1 Release Notes
 Updates
 o Add metadata with the version number of the database layout (#2474)
 o Split coordinateoperation.cpp and test_operation.cpp in several parts (#2484)
 o Update to EPSG v10.008 (#2490)
 o Added the NKG 2008 and 2020 transformations in proj.db (#2495)
 Bug fixes
 o Set CURL_ENABLED definition on projinfo build (#2405)
 o createBoundCRSToWGS84IfPossible(): make it return same result with a CRS
   built from EPSG code or WKT1 (#2412)
 o WKT2 parsing: several fixes related to map projection parameter units (#2428)
 o createOperation(): make it work properly when one of the CRS is a BoundCRS of
   a DerivedGeographicCRS (+proj=ob_tran +o_proj=lonlat +towgs84=....) (#2441)
 o WKT parsing: fix ingestion of WKT with a Geocentric CRS as the base of the
   projected CRS (#2443)
 o GeographicCRS::_isEquivalentTo(EQUIVALENT_EXCEPT_AXIS_ORDER_GEOGCRS):
   make it work when comparing easting,northing,up and northing,easting,up (#2446)
 o createOperation(): add a ballpark vertical transformation when dealing
   with GEOIDMODEL[] (#2449)
 o Use same arguments to printf format string for both radians and degrees in
   output by cct (#2453)
 o PRIMEM WKT handling: fixes on import for 'sexagesimal DMS' or from WKT1:GDAL/ESRI
   when GEOGCS UNIT != Degree; morph to ESRI the PRIMEM name on export (#2455)
 o createObjectsFromName(): in exact match, make looking for 'ETRS89 / UTM zone 32N'
   return only the exact match (#2462)
 o Inverse tmerc spherical: fix wrong sign of latitude when lat_0 is used (#2469)
 o Add option to allow export of Geographic/Projected 3D CRS in WKT1_GDAL (#2470)
 o Fix building proj.db with SQLite built with -DSQLITE_DQS=0 (#2480)
 o Include JSON Schema files in CMake builds (#2485)
 o createOperations(): fix inconsistent chaining exception when transforming from BoundCRS of projected CRS based on NTF Paris to BoundCRS of geog CRS NTF Paris (#2486)
More information about the PROJ mailing list
