[PROJ] How to set target crs in PROJ-data
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Mon Jan 18 04:06:59 PST 2021
Traditionally, EPSG has been linking 3D CRSs to 1D physical heights, however this transformation method (e.g. transformation code 9665) is strictly speaking not reversable, since the horizontal coordinates are lost. A year ago, I discussed with EPSG the idea of linking 3D CRSs to a compound CRS of their corresponding 2D CRS + the 1D physical height instead, which would be better as it is reversable. This would require a new EPSG method, so it wasn’t easy to introduce. I am wondering if EPSG did introduce that method now (transformation code 1088?).
Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210118/977698f5/attachment.html>
More information about the PROJ
