[PROJ] Questions about declaring a CRS
Alan Snow
alansnow21 at gmail.com
Mon Jun 28 07:54:20 PDT 2021
This may be a useful reference on the topic:
https://pyproj4.github.io/pyproj/stable/build_crs.html
On Mon, Jun 28, 2021 at 9:47 AM Floris Vanderhaeghe via PROJ <
proj at lists.osgeo.org> wrote:
> Hi,
> Below are some questions about the usage of 'PROJ strings' (as opposed to
> using WKT or AUTHORITY:CODE) as an option to declare the CRS of
> coordinates. The context is geospatial work in R with PROJ >= 6, the fact
> that users *can* still input PROJ strings to declare an object's CRS, and
> the question what to advise to users. We already had some discussions on
> this in the R-spatial community, which lead me to posing some questions
> here.
> After reading through several PROJ documentation pages, and observing
> output from 'projinfo':
> 1. It is clear that currently, support for representing a CRS by using
> a PROJ string is only partial, especially because the datum can often not
> be specified. ==> *QUESTION*: *Is specifying a CRS with a PROJ string
> going to receive continued support, or will it eventually be dropped? And
> related with that, **[QUESTION:] should we still advertise and use it
> to represent a CRS?* The current state may appear somewhat unclear:
> - There is support for '+type = crs' (to declare a CRS)
> - e.g. projinfo does accept a PROJ string as input to represent
> a CRS, by inclusion of '+type=crs'
> - There is (still) support for '+towgs84' (to declare a
> BOUNDCRS, hence not defining the datum directly)
> - Cf. mention of '+towgs84' in the context of a pipeline, in
> https://proj.org/operations/operations_computation.html#when-the-source-or-target-crs-is-a-boundcrs
> - '+towgs84' can be still used in a PROJ string that represents
> just a CRS (combining '+towgs84=' and '+type=crs')
> - However, PROJ strings are now generally described in the
> documentation as representing a coordinate operation, including datum
> *shifts* when using a pipeline string. That is, the pipeline itself
> does not define input and output datums, but may contain a transformation
> step to perform a datum shift.
> - In several places the *deprecation* of '+towgs84' is referred -->
> *QUESTION*: *will '+towgs84' be dropped eventually? *
> - Although using '+type = crs', the datum cannot be specified: it
> is WGS84 when no '+ellps' is provided, and else 'unknown'. But with an
> unknown datum, the CRS is incomplete. *QUESTION*: *Will** '+type =
> crs' get continued support, or is it intended to eventually end support for
> '+type=crs'?*
> - A comment in the second code chunk under
> https://proj.org/development/migration.html#code-example clearly
> disrecommends PROJ strings to define a CRS (as opposed to WKT or
> AUTHORITY:CODE), but generally this advice seems rather sparse in the
> documentation. In fact, the still-supported use of a PROJ string to define
> a CRS is only touched under proj_create()
> <https://proj.org/development/reference/functions.html#c.proj_create>
> and discouraged.
> 2. *If PROJ strings should not be used to define a CRS, then: *[
> *QUESTION*:] *is it possible, with currently advised methods, to
> define a **custom** CRS in a relatively short way*, i.e. not having to
> write out a full WKT? Perhaps having the possibility to refer an authority
> CRS (just using its code or name), and a way to alter specific (WKT?)
> parameters, could work, although I don't know whether specification of the
> second part can be standardised easily.
> Thanks in advance! I am not an experienced PROJ user.
> With regards,
> Floris
> *Floris Vanderhaeghe*
> Flemish Government
> RESEARCH INSTITUTE FOR NATURE AND FOREST
> Team Biometry, Methodology and Quality Assurance
> Havenlaan 88 bus 73, 1000 Brussels
> Belgium
> floris.vanderhaeghe at inbo.be
> www.inbo.be
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Alan Snow
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210628/4a41c75d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210628/4a41c75d/attachment.png>
More information about the PROJ
