[PROJ] Questions about declaring a CRS
Floris Vanderhaeghe
floris.vanderhaeghe at inbo.be
Tue Jun 29 08:59:17 PDT 2021
Thanks!
I had misinterpreted the short metadata 'remarks' at EPSG:6326
<https://epsg.org/datum_6326/World-Geodetic-System-1984-ensemble.html>.
Adding some references here:
* The 'datum ensemble' concept is defined by OGC
<https://docs.opengeospatial.org/as/18-005r4/18-005r4.html#97>.
* More extensive explanation on the WGS84 ensemble (2019) is (e.g.) at
https://dpipwe.tas.gov.au/land-tasmania/datum-modernisation/web-mapping-and-wgs84-web-mercator.
And it is referred in
https://www.iogp.org/blog/epsg/upgrade-of-epsg-dataset-data-model/.
Floris
mailhandtekening
*Floris Vanderhaeghe*
Flemish Government
RESEARCH INSTITUTE FOR NATURE AND FOREST
Team Biometry, Methodology and Quality Assurance
Havenlaan 88 bus 73, 1000 Brussels
Belgium
floris.vanderhaeghe at inbo.be <mailto:floris.vanderhaeghe at inbo.be>
www.inbo.be <http://www.inbo.be/>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210629/d2422a98/attachment.html>
More information about the PROJ
